its not vacuum, its not the floats........i have 18 inches of vacuum supplied from a electric vacuum pump separated from the motor for the booster, to stop the stalling when you are letting off the throttle, install a dashpot.
(spring loaded plunger for throttle lever to hit at idle position)
the wheel doesn't need to be reinvented. the round wheels work fine.
