Old 05-11-2009, 02:07 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Greg,
Trying to figure out what belts/seats you have and why you can go forward? What kind of mounting are you using for the back belts?
Obviously I have raced for many years all over the country and always passed tech without a problem? Only when I hit 11.01 did I get some pretty direct stares (10.99 required a full cage!)
Anway I'm sure I can come up with something for you. How about a cross bar (will need to be welded) with four tabs welded on to bolt the harness' to?
A true legal cross bar that bolts in would be absolutely do-able but pretty darn exspensive!
DV
Or is that the whole point, to get away from welding?
