Originally Posted by ou812545
It appears to be a rear main, but the source can be a number of places.
The dye kit will point you in the right direction. You'll be able to see if the intake is leaking, valve covers, etc.. I thought my leak was a rear seal failure, but it ended up being an
oil galley plug on the back of the block (which meant that the transmission had to come out).
