Originally Posted by Philm
Merv,
You can increase the output of a 302 without a bunch of new fancy parts.
You can rework the engine you have, new set of pistons and rings give the bores a machine and hone. Clean up the heads to make them flow better.
Then I would increase the comp ratio slightly and with a slightly higher lift cam would see a good gain in performance.
then you will have the sound of angles singing that only a 302 windsor produces..... That is for you Les.
Phil
Spot on Phil
hehehe re angles singing, couldn't agree more
Time for Uncle Les to clean out his ears again
