05-14-2009, 07:52 PM
Ont
Originally Posted by FUNFER2
When I was setting up my suspension, I made two 8" length of round aluminum that was threaded inside, and bought four heim joints to make shock replacement. I removed the coil overs and mounted these in place. I was able to adjust the ride height where I wanted and since we race sprint cars, we know a lot of modified racers so, I borrowed a set of four weight scales.
Before I started, each corner was so different in weight, I could not believe it. After adjusting, the weight is almost the same on each corner and the percentage front to back now is 51% in back and 49% in front.
Here's a photo of the tool I made. If your interested in making a couple (it's cheap) let me know or I could mail them to you, just for postage costs.
It's the best tool I've ever had to adjust weight, measuring for wheel & tire size and setting ride height.
how do you adjust the weight at each tire? is it done by the ride height?
