Old 11-18-2001, 07:08 AM
jrussell's Avatar
jrussell jrussell is offline
Cobra Make, Engine: Superformance #586, 535hp.460
Default That depends on the actual verbage!
No matter what, I'll be at the meeting & vote!
Tom, as to your comment, If the "actual" verbage from the bylaws is what Gary wrote in the last newsletter, then you are incorrect.If the "actual" verbage is indeed different in that the word "sit" replaced the word "nominated", then you are correct. However, this would raise another problem, in which a member attended the required number of meetings"to be nominated to sit" on the board, then once elected, attended none!I do not believe that was the intent, & therefore I assume that what Gary wrote was correct. I WILL attend more than the minimum IF elected as this gives me a valid reason to miss 1 BoyScout meeting a month, but if it IS a pre-requisite, then I believe the bylaws are flawed.
Either way, I WILL be there.
John R.
