Old 05-17-2009, 11:48 AM
elmariachi elmariachi is offline
Unplug the 6AL from the dizzy and jumper the purple and green wires coming from the 6AL unit. Then remove the coil wire from the dizzy cap and get it near a ground. Crank the engine. If the coil wire sparks over to ground, the 6AL is firing. If not, its dead, assuming the rest of your wiring is correct.
