Old 05-17-2009, 09:52 PM
tkb289's Avatar
tkb289 tkb289 is offline
Originally Posted by Dangerous Doug View Post
Tim,
You already know most of my advise:
Powder-coat and bonded body option
Have ERA install the front suspension (which, as a roller the point is moot...)
SINGLE HOOP ROLL BAR (I know... I know...)
Ford Crate 302
TKO-600 with 0.82 (I have 3.54---lots of giddyup, and good cruising speed)
ERA rear with outboard brakes
15" tires the right size are getting harder to find, Firestone Firehawks worked for me
I like the look of the bumper overriders (think that's what they call them, chrome bumpers instead of quick jacks---though, I like my quick jacks....)
You won't need an oil cooler in CA. I'm working on a panel to close off the lower portion of the intake (splits oil cooler inlet and radiator inlet) I'll show you what I am doing in about a week.
It's cheaper to have them do the paint with their vendor in CT. Painted roller is smart. That'll save you enough to plunk down the $2k for the TKO.
Oh, buy your TKO-600, clutch stuff from Mike Fortes. Use a Quicktime bellhousing, not the Lakewood. I can help you set up your hydraulic throwout bearing.
The most important decision, though, has already been made, and you chose well. ERA.
It's all good.
DD
Doug,
Thanks as always for the info ... it's great to have an example so close!
I'll have to take a look what the differences are between the 3.31 and 0.82 that was suggested, vs the setup you have with 3.54 and 0.82. They don't sound that dissimilar.
At this point, I will skip the oil cooler, but will probably leave the opening there, I like the way it looks.
Have fun with your car!
- Tim
