05-18-2009, 12:56 PM
Cobra Make, Engine: SPF#0760
Have you checked the joints an the steering shaft. Drivers side, inside the engine compartment. 2 clevis joints. The older cars had a design that developed some play after time. You can also check to see if they are properly connected to the steering shaft stubs. I've seen loose connection here before.
SPFWiringDiagrams@Comcast.net
