Old 05-19-2009, 08:08 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Have you inspected your drive shaft hoop? Maybe look for a rub mark. And how about your rear sway bar connections, are the rubber pieces secure. You car is quite new so I would guess they are fine...With the rear wheels off the ground, is there any side to side movement of the tire and rim? That could be caused by a loose wheel hub or axle nut(s) Brake calipers mounting bolts tight? Spinner tight? Do you have the newer parking brake desigen? Does it work well? If not, maybe a loose brake pad or PB pad? All things to check if you have not yet.
SPFWiringDiagrams@Comcast.net
