Old 05-22-2009, 02:29 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
Default Rear Main Seal -- leakleak..leak.
Ok, so i have a puzzle here , we have a 289 in house that is driving us nuts.
it is a 2pc rear seal, and it has been sleeved. (rear main) the sleeve is .08" larger than stock OD and we have tried stock type neoprene seals and a rope-graphite seal - and it still leaks.
Neoprene is inserted into clean channel with permatex 400 sealant.
-we checked crank case pressures and PCV setup and they are good, compression is 120psi on all cyls and leaks less than 5%. --so it is not blowby.
any ideas >?
--Steve
