Originally Posted by Rick Parker
Sounds like time for a little manipulation with a Ball Peen Hammer??? Or shorten the studs & use 12pt nuts which are a little shorter.
Absolutely.
Originally Posted by lineslinger
I thought that was your tool of choice Rick?
Try this stuff, Aviation form a gasket. I have rebuilt 3 british engines using it with zero failure. Its serious stuff, don't get in on you.
Three British CAR engines or three British aviation engines??? Either way, you sure are hard on yourself trying to mate two British-engineered surfaces together and then expect no leaks.
