Originally Posted by Ronbo
25lb intake? (well almost all iron)
Not sure about that 17lb starter either. (maybe it just seems like more when your on your back trying to hold it in place while getting a bolt started)
That hi-po job evidently got the benefit of the PI intake. I think that 17 lb. number is pretty close -- I've got that monster starter on my FE. You could shave 10 lbs. off right there. Ronbo, you've got the aluminum block, don't you? You're probably down in the low 500's.
