Old 05-23-2009, 03:04 PM
Rick Parker's Avatar
Check the way it is mounted. It is best to keep the outer tabs in compression with a spacer, and isolate with a rubber mount if possible. If you are mounting it by the lower tabs only, vibration or twist may also be involved.
Rick
