Thread: Cam Degreeing
Old 05-24-2009, 10:38 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
the .006 numers are hard to validate/check--thats why everybody uses .050 numbers
you said you liked the lobe c/l method and that it was just ONE degree off---does thay mean 1/2 +-??????
In the first or last .006 of lift you will find very little sognifinance??
I do assume that you are checking at the lifter, with correct type flat tappet or proper radius roller???
