Old 11-19-2001, 04:59 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
When you lose the band or governors, the trans doesnt 'lock up', it loses whatever gear the band engages. In your case, I think you lost the low band because you lost all forward gears. May have lost a sun or planetary gear too. Only a teardown will tell. You can run a pressure diagnostic on the trans in the car if you have a 300 psi pressure gage with HEAVY DUTY 1/8" line with an 1/8" NPT fitting. The diagnostic pressure port on a C6 is just brhind the linkage that retains the backup light switch. It's a small hex plug. NOTE: DO NOT EXCEED 20 SECONDS TEST TIME IN EACH GEAR OR 2 MINUTES TOTAL TIME---YOU WILL BURN UP THE TRANS!!!!! Hook the gage up to the port, and measure your pressure readings at idle with the brake applied, than compare to the normal:
Neutral---50 to 80 psi
Drive 1 and 2--50-95 psi
Reverse--60-150 psi
If you do this and post the results, I will post the correct diagnostic flow chart to help you find the problem.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
