Originally Posted by boris_thespider
Is there a methodical way of working backwards from the master cylinder to check for problems? Thanks...
Mike
Start bleeding from the right rear caliper first, then the left rear followed by the right front and finish with the caliper closest to the MC. I have always had trouble with the self bleeders. I use a long small plastic tube connected to the bleeder and immerse the other end in a jar of brake fluid to see more clearly when the bubbles disappear.
Scott S
