Old 05-25-2009, 12:39 PM
olddog olddog is offline
Originally Posted by SantaFe66 View Post
Ford FE big block 650 (Deduct 100# - alum hds, 50# - alum intake)
(332-428 CID)
The above came from: dave.williams@chaos.lrk.ar.us
He published a pretty complete list of engine weights for many makes on the web.
The spreadsheet had 86# for bare heads. Based on how it added up, I took it to mean two heads equal 86# or one is 43#. If that is so, Aluminum cannot save more weight than what the iron parts weight. So what is the correct weight for the heads?
If I add 33# that Barry said an aluminum intake runs, to this 50# savings, then an iron intake should tip the scales at 83# give or take. Does that sound correct?
Thank you very much for the spread sheet. I collect tid bits like this.
