OK - put the air cleaner back on.
What kind of ignition system do you have?
Grab hold of the distributor and see if you can turn it - you shouldn't be able to.
Pull the distributor cap off and just look around inside the distributor - If you can identify the rotor, look at the brass piece on it. See if it moves in any direction. It shouldn't.
- I realize you said you don't know anything about this stuff, but just go slow.
