Old 05-29-2009, 06:31 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I don't have an IAC also and I don't touch the gas when starting. You may need to adjust your plates open a little, realize you need to open both sides equal or you could get some backfire... which might be something you want to check to start off with. Does it backfire warm, it is the same cylinders? What is your cold, idle, open-circuit fuel ratio? Does it backfire when cranking to start?
