Old 05-30-2009, 04:20 PM
strictlypersonl strictlypersonl is offline
When the suspension is at full droop, the lower control arms hang substantially below the plane of the chassis outside the main frame rails. Consequently, the only possible path for the pipes is under the main frame rails. With a normal ground clearance there of 5.5", you'd end up with around 3.5" ground clearance, even with oval pipes.
