Originally Posted by DAVID GAGNARD
EL; I would definelty put on a smaller diameter water pump pulley,the water pump pulley should be at least one inch diameter less than the crank pulley....
That's one of the things we were discussing last night with a few other owners at the car show. It can't hurt anything to drive the water pump a little quicker.
Electric Fan is cranking in the right direction, it blows air out the back on the driveway and will suck a paper towel in the nose up against the radiator.
Originally Posted by LMH
Just a thought but while sitting still, when it starts to overheat, raise the RPM up a little and see if the temp comes down. That might tell you if it's a coolant flow issue.Larry
It will cool 3-5 degrees briefly by revving the idle. Then it continues to climb. One thing to note about the flow. Let's say I heat it up to 100C, then shut it off but leave the electric fan on. After about 3 minutes of the fan cooling the radiator if I start it, it immediately drops down 10* as it sucks the cooler water in out of the radiator. I can kill it, wait a couple minutes and do it again, and I can get from 100* down to 80* in 5-7 minutes like this. So I think that suggests I am getting good flow, no?
