06-01-2009, 09:07 AM
KY
What's your initial timing set at? You can try giving it a couple more degrees, then turn your idle back down to compensate.
You can also adjust your mixture so that it's a little richer than before. This will sometimes buy you a little bit of lee-way and you can turn the idle speed screw down a little bit to compensate.
Last but not least....does it need to idle that high?
