So you mean your pulleys won't let me run A/C later?? Single groove is exactly what I need. Here's some good reference info on compatibility, the water pump pulleys are half way down the page: http://www.mustangtek.com/pulley/Pulley.html
Thanks!
I did a quick google search and from what I can tell, the 4 mounting holes and the center hole should be the same for a small block Ford up to the 427s, that's the good news.....Only thing is the pulley depth that varies and yours is 2.5 inches....
I'll go thru my pulleys tomorrow and see what I have with the 2.5 inch depth and see what diameter I have and let you know....I got a bunch of them, so hopefully, there will be one in the pile that fits your size........
David
