Originally Posted by razerwire
Have a 4" thick, 18" tall, 22" wide fluidyne radiator. one 16" puller fan with no shroud. two pusher fans just for looks , but can switch on if I want to, outherwise they freewheel. most important nose of car finished so all air has to pass thru rad. Also very,very,very important 20 deg tilt to rad. 468 fe engine ,las vegas, 80 deg c. 950 rpm idle 80 c. down road. car does not overheat. Note 0 deg would mean rad. is vertical, degree finder shows 20 deg when placed on top of rad.
Well that just about does it for me.
My radiator is 27W x19Hx3T and is tilted 25*. The off-the-shelf Fluidyne for Cobra is FHP30-SHELBY and is 23.65W X 18.0H X 3.5T. I am guessing this is not your radiator so did you have them make a larger one with the Cobra connections or did you use a different model? I just talked with them and they'll make a cusstom size with Cobra connections for $150 more. I guess I could go that route and just not send my kid to college $$.
For those who know, could I not use the off-the-self Fluidyne and just shroud the front sides to cover up the 2" difference on each side?
