Thread: Weber Experts
Old 06-03-2009, 06:15 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Snake bit,
I would check the floats. If you are running an electric pump, I would fill the bowls and measure to see if 1 side is the same as the normal side.
I did this and used a seringe to extract the fuel. Place the fuel into a measuring cup and you will have your results.
I would also check the needle valve. I have seen different needle valves give different results.
