  #98 (permalink)
Old 06-03-2009, 09:59 AM
elmariachi elmariachi is offline
Originally Posted by razerwire View Post
If you talk to fluidyne you could ask them what Finishline Motorsports Las Vegas used in the comp cars and what the specs are. I would call Finishline for you but they are closed. Then you could compare specs to your rad.
That's model FHP-30-SHELBY, same as discussed above. Its a 3-row versus the PRC 2-row. I am pretty sure I can make it work and use sheet aluminum to enclose the side up front in the nose. Its already setup for the correct driver-in, passenger-out ports and has the air bleed port from the expansion tank. The PRC Hurricane radiator requires a passenger side main hose exit on the expansion tank, reverse of the Fluidyne. This coming after I finally got my expansion tank to stop leaking. So I got that going for me.
Restrictors and new IR gun arrive tomorrow, then we'll be doing more testing.
