Thread: Weber Experts
Old 06-03-2009, 02:33 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
GAZ64,
I have heard this before in the past but does nto seem to work for me. Reason being, if you remove 1 etube stack and look down the well while removing the 2nd etube you will notice a huge difference in fuel height. For this reason I have decided to measure the bowl with both stacks in stalled remove the top cover then the float. Then take a seringe to suck out the fuel in to a container to measure the CC volume. This takes time but I know my float levels are exact. The seringe I use was about 8in long with a 1 inch diameter. I belive it was a 50 ML syringe
