Originally Posted by patrickt
Let me play Karnak the Magnificent -- I See, I See, I See... a leaky clutch slave cylinder, which is found mounted on the driver's side of the transmission/bellhousing.
Actually, I'm not on the case, but someone will be - on Monday.
Anyway, his only questions relate to 'PARTS' - in may not result in any parts, but if it does - are there parts and will be hard to get - is there a list of replacement parts related to this sort of issue?
Actually, over the years of ownership, not much has come up but when it does - replacement parts is always the issue - my Cobra was ERA factory built in the late 1980's so even the parts used at that time have changed in some areas.
So, if there is any input relating to replacement parts that I can pass on to my man depending on what he runs into - that input will be sincerely appreciated.
