Old 06-03-2009, 08:17 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
nice john, hang in there.
it's just me but i would split those headers at the flange and keep them from leaking. do it before you coat them and it will look fine. definitely don't want any leaks with the o2 sensor.
keep the pics coming.
did goins make that chassis?
look forward to seeing you at run n gun.
getting ready to install the dash? i split mine to the right of the steering column and used rivnuts across the bottom at three attaching points and then drilled through the top from the front at two places and used cap head screws to hold the dash at the top to aluminum plates behind that were drilled and threaded, makes for easy dash removal which i can do sitting on the tunnel. the split is the width of a hacksaw blade and is never seen unless you tell someone, just color the aluminum with black marker.
