Old 06-05-2009, 09:12 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Full Throttle Al View Post
If all out performance is what you are after, go with the Berg Carb, now available to 61mm but the footprint is still the same as the 48mm IDA.
What's the cost difference between a full brace of Berg carbs, and a Dynatek EFI setup? Also, the Berg carb is considerable taller, looks like hood clearance will be an issue on most Cobras using the Berg carbs.
Lots of looks at neat Weber manifolds here, but the base question remains unanswered...is there any performance difference between all these different Weber manifolds, or are the differences mostly cosmetic?
