Old 11-20-2001, 08:50 PM
Cobra2 Cobra2 is offline
Ratsnake. I mounted the lever on top of the console just to the right of center and toward the back but where I can reach it comfortably. There is a bracket on the calipers that holds the end of the e-brake cable housing. The cable setup is stock corvette supplied by EM, it consist of two cables and an equalizer bracket. The cables come around the trailing arms tight but seem to work just fine. I believe I modified the front cable to lever hookup with a cable stop that came with the lever.
Type in this URL to see a pic of the lever installed.
http://www.geocities.com/bourbonstreet/3683/finin1.jpg
