say your injectors flow 40 lbs an hour at a certain psi, 8 injectors at 80%duty cycle would be 32 x 8 = 256 #'s per hour, fuel is 6 or 7 lbs per gallon, or 35-40 gallons per hour, or what you said.
everytime i turn around it seems i have to fill up the jbl, 12 gallons doesn't go very far with 11-15 mpg.
that reminds me of an interesting article i read but can't find now, they did an experiment with different a/f ratios. they started at 16 or 15-1 and an engine at wot only lasted a few minutes, they kept increasing the ratio and at 12-1 the engine still only lasted about 20 min. before it burned a hole in the piston if i remember right.
