Hydraulic TO bearings
Is the bleeder line on the top of the TO, not the bottom? What's the diameter and travel of the clutch master's piston? Make sure the volume of fluid is sufficient, but not too much so as to overextend the TO. Vacuum bleeders work well for hydraulic TO's. Fill the resevoir, suck it almost empty with a vacuum bleeder at the TO. do this three times, then get a helper for pressure bleeding(traditional, you pump and hold, I open the screw and close before the pedal is released). The hydraulic TO's need to be adjusted prior to install to set the clearance to the clutch fingers. .100" is perfect with the TO fully compressed.I've done a hundred of these on Cobras alone, if this doesn't answer your questions, email me.
