Old 06-08-2009, 10:29 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default cylinder with a wet plug using efi
hello all
have a cylinder with a plug that comes up wet and rich looking with black soot. other plugs all look normal and dry, affected cylinder (#2) leakdown is similiar to cylinders on either side. the cylinder is also getting spark, the condition has appeared on 2 different plugs in the same cylinder. the plug is not oily, just wet, as in gasoline wet. the cooling system is in good condition and don't believe it is leaking. doesn't appear to be a miss on the cylinder either.
i'm thinking the injector is leaking or running too rich or something. what would be the best way to check that the injector is firing correctly, i'm thinking of swapping it out for another and see if the condition follows or stays on the same cylinder.
