Old 06-08-2009, 10:40 AM
jczar jczar is offline
Cobra Make, Engine: Midstates, 351Cleveland
Originally Posted by strictlypersonl View Post
Don't forget that stiffening the rear coils will increase oversteer, so it might not be the best way to deal with your situation. You may need a rubber cushion to prevent the shock from bottoming out or a damper with a shorter closed length.
Thanks for the advice. I'll try some cushions and if that doesn't solve my problem I'll call Aldan. I read in the above emails the general manager works with you on determining what works best. I'll mention the possibility of oversteer.
