Old 06-08-2009, 02:24 PM
LeonardU LeonardU is offline
Cobra Make, Engine: Contemporary, 427 SO
Default Bleeding the Clutch Slave Cylinder
I need to bleed the clutch slave cylinder on my early Contemporary Cobra and need help. I tried to bleed it myself with a Mighty Mite and it didn't work. I have been told that I need to bleed the master cylinder first manually by using the clutch pedal, but I can't locate a bleed fitting on my master cylinder for my clutch. Has anyone used a brake bleeder that works with a air compressor to power bleed the system? Any help would be appreciated. The weather is great and the car sits on stands. I need to get the Cobra on the road. Thanks for any help.
Len
