Old 06-08-2009, 07:08 PM
DAVID GAGNARD's Avatar
Originally Posted by JohnM View Post
Hello All,
I was wondering what test or suggestions you might have in regard to my battery always being dead. I have had the alternator checked and it tested OK
I put it on a battery charger and it fires right up etc, If it sits for 7-10 days not enough power to kick it over. The only thing electrical that is running is the second hand on a dash clock
Looking forward to any ideas
thanks
John
My 65 Mustang does the exact same thing, only thing "on" is the clock/radio settings drawing power... My car sometimes sits for 2 weeks or so and will not start it,but does turn the battery over too slowly.....
It may take a while, but pull out one fuse at a time, start with the one that handles the clock, that way by doing it one at a time, you can isolate the problem to one circuit....once you find the "bad" circuit, then began disconnecting things on that circuit one at a time to fing the offending source..........
it's slow process, but it works...........
David
DAVID GAGNARD
