Originally Posted by JohnM
Hello All,
I was wondering what test or suggestions you might have in regard to my battery always being dead. I have had the alternator checked and it tested OK
I put it on a battery charger and it fires right up etc, If it sits for 7-10 days not enough power to kick it over. The only thing electrical that is running is the second hand on a dash clock
Looking forward to any ideas
thanks
John
This is a shot in the dark, but if you have an MSD ignition and if the main feed wire (heavy gage red wire) is not fed through a relay or other switched source. The MSD will drain the battery in about a week even if the control wire from the ignition switch is off. I use a battery disconnect switch because of this and have used the same Optima battery now for 5 years with no problems even after letting it sit for 6 months with out charging.
