John,
The p/n for the Hotchkis adjustable trailing arm set is P/N 1204AA. This gets you everything that you need for both upper trailing arms.
JAC,
Mine is stock CR LTD from what I know. Using the upper frame holes for the upper trailing arms my trans and rearend are out of alignment almost 5 deg. This could be from wornout bushings, different motor and transmission mounts, I really am not sure. I got them because I have a vibration on acceleration that I am trying to work out.
How is your CR coming along?
Terry
