06-09-2009, 08:05 PM
Cobra Make, Engine: SPF#0760
I'm sure all have you have searched for the source of this issue on your cars. I would probably approach the issue in the following ways.
Have you ever just disconnected the MSD box for the usual period of time required to drain the battery? Same thing for removing one fuse at a time for the same duration. At lease you would determine the circuit the drain is assosiated with. The most common things I've seen are: a bad cell in the battery, improper charging because of a faulty voltage regulator, bad alternator, improper cable sizes, wrong location for wire connection from voltage regulator...and the biggest electrical problem...bad/undersized grounds. Hope you find it or a good work around...
SPFWiringDiagrams@Comcast.net
