A quick update. I do have an MSD ignition, and a battery disconnect. I have the radiator fan on direct feed so that it can run when I put the car away in garage after driving with the battery disconnected. The fan takes alot of juice to run but doesn't run very long after the car is put away..just 2-3 minutes
The only other direct wire is the clock with it moving second hand.
I will look into this MSD situation
thanks
John
