Old 06-13-2009, 03:53 AM
Double Venom's Avatar
Double Venom Double Venom is offline
I think your painter is talking about "Imprinting". It happens on any color with poor fiberglass or improper preperation prior to paint. Since ERA uses a high quality fiberglass and gelcoat you should never experience this problem, regardless of the color. A high quality Sealer is critical and following the directions is also critical. Nothing like a black Cobra with a two foot shine/reflection! best thing I have found is to put ther car in sealer-two coats- when it is ready for paint. Move it outside in the sun for a couple of days, causing the sealer to shrink and to allow the chemicals to work out of the sprayed sealer
Wet sand, (yes, wet sand the dried sealer) and put down your color. Now paint it black with two-three coats of high quality Clear that has plenty of UV protection- BASF,Dupon't etc.
My 2-cents-have never had the imprint problem With, ER!, EM, Midstates, Cr's, or SPF'.
DV
