Old 06-13-2009, 07:07 PM
67JET's Avatar
67JET 67JET is offline
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
Default Change MGB front end to Tubular A-arms?
I found a website http://www.fastcarsinc.com/ifs.htm but im not sure it's the answer to my problem. I want something adjustable and i like the tubular front ends on all the other Cobras and wonder if i should try to totaly change my set-up. I don't want to change the entire front frame section but would cut and weld on what i got. How bout some opinions. For the money 3825.00 i can get an entire front end with bigger brakes and coil overs with rack and pinion already set up --- or--- cut it all apart and start over. Where do i look for the right tubular front set-up and brakes and coil overs and rack to do it myself? Some opinions from all you trained professionals with years of experiance would make my decision easier. Thanks
