If your door is out of alignment by very little then the extended part of the door hits the body when you open it. Been there, done that. On the top of the extended area.
Edit: This could move the door about 6 inches further away from you when the door opens. The door opening in the body is the same size but it will feel like you have a lot more room. I think.
Terry
Reason: added edit info
