Old 06-15-2009, 12:24 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
I first asked Ted about chroming the control arms and he was reluctant. Then, about a week later we talked and he said what if I were to chrome the K member and all. I told him to go for it. He did it all.
Remember, I didn't install it, but 4 bolts hold the K member in place. The rest comes as a complete front end, K member, rack, everything including Wilwood brakes, rotors, etc. It should not be difficult according to Ted. Mine was a little different because he had to make special spindles for the brake calipers and the 6 pin hubs. None of that will be a problem if you use his front end as a package. Give him a call, he is a real nice guy and tell him I asked you to call. He is great to work with and he will help you with anything you need.
His complete setup should bolt right in. I assume you have a Butler or Arntz, is that right? If not, it should not matter because his kit replaces K member and all and it is built for MGB.
Hope this helps.
Russ
Russ
