Old 06-15-2009, 09:06 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Mike,
I looked at going with Hoyle, but decided on Fast Cars because I wanted to use the 6-pin hubs and the JFZ calipers. Making the spindles and adapting the 6-pins was above my paygrade. So, for that reason I decided to go Fast Cars.
The only thing important here is that you are happy.
Jet,
I believe Holliday is in Huntsville, Tx. Heard some good and some bad about him. You probably made the right decision to do the upgrades yourself. I believe Fast Cars suspension should fit if Holliday used the MGB K-member.
Anyway, hope it works out for you whichever way you go.
Guys, thanks for the nice comments.
Russ
