Thread: TKO 600 noise
Old 06-16-2009, 12:28 PM
maxum_101 maxum_101 is offline
the clutch is a centerforce clutch, i was under the car and can see thru the hole where the clutch fork goes. now when looking at it i see that the throw out bearing is always spinning even while in neutral, is it supposed to be like that? i alway thought that the thro out bearing only spins when you press the clutch in.
now i also noticed that my clutch fork moves a bit up and down in the hole in the bell housing and because of that the threaded rod tend to not push out in a straight line, and eventually the fork will drop down and then the threaded rod is on a bit of an angle, i hope im explaining this that you can get an idea of what im talking about.
