Thread: TKO 600 noise
Old 06-16-2009, 01:54 PM
madmaxx madmaxx is offline
This is a ridiculous diagnosis. A new tko 600 and associated bell housing, clutch, install, would run $3K where the heck is $6.5k come from. You are way off on your diagnosis. If you like to give money away send some to Obama.
Originally Posted by RICK LAKE View Post
maxum_101 If the noise goes away with the clutch pedal engaged, It's either the thrown out bearing or the pressure plate springs broken in the disc. You are going to need to pull the trans to repair. I would also tell you to get another clutch from another company. E-mail Brent B. on this forum. He sell clutches of different styles for the best prices. I had major problem with a Centerforce that cost me $6,500.00 to fix. If you stay withthis clutch remove the weights on the pressure plate. This will to shifting issues at about 3,000 rpms. Rick L.Ps there's Brent
