Originally Posted by Cobra 29
I have a Centerforce PP with the weights and a new TKO600, after reading this, I think I want to remove the weights. Can this be done with the engine and transmission in the car? I thought I remember reading a thread where a CC member successfully removed the weights and bar that holds the weights via the fork splot in the bellhousing. I believe he said he counted 18 weights so he knew that he removed them all and left none at the bottom on the bellhousing.
Your thinking of Chuck Brandt's web site where he talks about removing the weights, but I don't believe he did that through the clutch fork hole. Here's a shot of my CF setup before the weights were removed. I don't think you can do it through the clutch fork hole (and there weren't 18 weights on mine).
